I have reinstalled SkyStar2 with drive v4.4.0 and then reinstalled ProgDVB
v5.13.4
In Settings/Options all five tabs display at once and its a jumble.
Main, Direct Show and the others all display at once.
I can't see the default settings in Direct Show and I can't make my settings.
On the TV screen I have error box Information. H264/AVC andDVB-S2 supp only in Pro version.
I need to correct these settings in Direct Show
Help Please
This is weird, very weird...
Perhaps try to delete the ProgDVB.ini and start again with all settings.
I can delete the ProgDVB.ini but could you explain what you mean by start again.
(I'm not a computer minded person, but I try)
As a test I installed my previous version into a My Documents folder, then removed the ProgBVB.ini from the new v5.13.4 and replaced with this older one. That didnt work and I still got the jumble.
So I reversed it and removed the previous version completely.
Mike
Mike
Make sure ProgDVB is not active.
Remove ProgDVB.ini
Start ProgDVB (without it).
Now you will to go through all settings and options again.
When closed again, ProgDVB will create a new ProgDVB.ini, containing your new adjustments.
In most similar cases this helps.
Remove ProgDVB.ini
Still not working. Going out for a beer, or two.
This morning I downloaded and installed v5.13.4 five or six times without success. Then I tried downloading and installing older versions.
No success with a v5 then v4.89.04 seemed to work but then I got the windows error message and closed.
v4.85.3 worked. although Direct Show is in the old format and not under Settings/Options.
Then I found your explanation re Progdvb.ini
I've tried this method all afternoon on v5.13.4 but with no success.
I tried removing the .ini and rebooting or not rebooting before going back to settings.
I hate computers and I've missed the Ladies Tennis.
I 'll go back to v4.85.3 in the morning.
