how to configure remote control ?
smartpal
smartpal
Sun Mar 09, 2008 10:39 pm
#1 by smartpal
hi there ,
I have VideoMate 300S DVB card , and it have a remote controll
but I cant make it (the remote control ) work with progDVB 5.13
do you have any ideas !?
thanks
  • Sun Mar 09, 2008 10:45 pm
I have some technical problem with VideoMate RC and current version not support it. I hope fix it in one of next versions.
  • Mon Mar 10, 2008 8:09 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 3:53 pm
