Remove transponder list pop up when opening progdvb
7wonders
7wonders
Tue Mar 18, 2008 12:18 pm
#1 by 7wonders
Hi,
When using progdvb for only iptv, there is no real reason for the transponder list pop up at start up. Is there any way to launch the program without the pop up or to remove it entirely??
Thanks
  • Fri Mar 28, 2008 9:37 pm
You must select your transponder list and push on OK.
  • Sat Mar 29, 2008 8:05 am
7wonders
7wonders
#3 by 7wonders
But I have no transponder list because I used the blind search to find the channels.
  • Sat Mar 29, 2008 11:27 am
Return to “IPTV”
Re: Вывод звука wasapi и asio
  • It is currently Fri Sep 18, 2026 12:22 pm
