v 6.0 Test - not working correctly for me
I tried to run v 6.0 32bit on my Vista x64 with 8 GB and 4GB of ram and I run into several problems
first some info on my setup
1) i don't have any plugins installed in this new version
2) its a fresh install in new folder so everything is installed from scrach
hardware config as in my signature the only one thing worth mentioning is that i also have a hauppauge pvr150 in (not runing at same time as my sat tuner couse those 2 cards don't like to work together at same time - got stream errors in both of them when both runing at same time - most probably irq issue)
hauppage is not working with analog tuner functionality of ProgDVB as this card produces mpg2 streem as output and this app cant build correct graph for it (can provdie correct graph if this would help include support for this type of card recognised as Hauppauge WinTV PVR PCI II (26xxx)
BDA)
now for my results with new ProgDVB version:
Install went OK program installed to run with Admin privileges by default (will not run without those privileges - no access to sat card)
First run:
cud not setup my lnb config till i set it to custom after that all controls unlocked (initially on diseqc settings window when i clicked on empty bellow my bda card none of the buttons for setting lnb/swich were active)
clicking ok after initial setup worked as expected.
channel scan seemd to be ok not sure if all channels found but all that im waching usually were there
IPTV seems to work OK at least for some stations i got picture and sound
now for problems
audio distorted picture displaing at 2-5 frames per second after changing language on sat program (solved by scrolling back and forth in timeshift bufer), when no bufder enabled swiching channels back and forth is the only way to resolve problem
occasional lockups after accidental swiching to scrambled channels (no CI or other decoders onboard)
next more grave problem after starting anything that causes UAC popup I often get windows message saing that Prog stoped responding and the app gets shut down (sometimes it seems locked but somehow starts responding before windows shuts it down, no sound tho. Situation seems similar to that when changing audio tracks/languages)
Im using windows builtin codecs for video and audio somehow they seem to work better (more stable) than elecard ones for me.
If anything more is needed just ask and I will see what i can find
VISTA ULTIMATE x64 Polish 4GB/8GB of ram
GForce GTX 280 Newest beta drivers from Nvidia Web (7.15.117813)
TechniSat SkyStar HD with TechnoTrend S2-3200 (BDA) drivers (5.0.0.19 dated 2008-03-04)
1,2m Dish DSQC 1.0 swich 2 converters pointed at HotBird and Astra
no plugins installed so far
