Works Hauppauge WinTV HVR 930-C?
cptmadman
cptmadman
Fri Oct 24, 2008 10:59 am
#1 by cptmadman
Hi,
I currently bought the Hauppauge WinTV HVR 930-C Hybrid Stick(USB), and tried to get it to work with ProgDVB, but it seems as the drivers are not recognized...
When i trie to set the bda driver manually, no channels are found...
  • Fri Oct 24, 2008 11:04 am
Try blind search
  • Fri Oct 24, 2008 11:15 am
ssteemann
ssteemann
Sat Jan 17, 2009 8:22 am
#3 by ssteemann
I have the same problem. No channels are recognized. The bda driver could be found but no channels even doing blind search.
  • Sat Jan 17, 2009 8:25 am
Lampone
Lampone
Thu Apr 09, 2009 10:33 pm
#4 by Lampone
have the same problem, no channels are found. Can anyone help, please....?
I am really going crazy...
Thx, for reply
  • Thu Apr 09, 2009 10:36 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 7:47 pm
