Hello..
I have a new Technisat SkyStar HD2 card.
Default drivers installed.
But ProgDVB 5.16.2 is not working.
When installing ProgDVB i choose Azurewave (Twinhan) BDA
Later.. ({BDA} DTV-DVB Mantis DVBS BDA Reciever)
And i only get this error..
Cannot load filter and connect.
and then this.
Device not started!
Any help is welcomed.
I have reinstalled driver 8 times..
Even changed PCI slot.
I still get the same error.
Thinking about reinstalling entire PC system.
Device selected did not start
I cannot select any modules
But i have selected azurewave/twinhan when installing ProgDVB.
No chance to move motor ???
#8I have Vista64-bit and Technisat Sky Star HD 2...
I tried almost all available progDVB versions... 32-bit versions are pretty slowly in response to mouse and cannot move motor.... Pro versions can display HDTV, but insufficient CPU...
64-bit version 6.02.03 can move motor, but this is not under control. Sometimes succeed move form one sat to other during channel search, but when switching between found channels in lists, no move occures...
I ask: Exists any ProgDVB 64-bit professional edition, that can regular move motor and also display HDTV ????? I didnt found it yet....
THX
THX
SS HD2, Vista64-bit
