SkyStar 2 PCI and Vista 64Bit
Nemosum
Nemosum
Sat Mar 21, 2009 5:35 pm
#1 by Nemosum
Hi,
I've downloaded the latest version of the driver and installed them, DVBViewer recognizes my card, however ProgDVB does not recognize my card?
  • Sat Mar 21, 2009 5:39 pm
You can use ProgDVB x32 or BDA driver.
  • Sat Mar 21, 2009 5:42 pm
Nemosum
Nemosum
#3 by Nemosum
worked! thank you very much indeed
  • Sat Mar 21, 2009 6:00 pm
KouDy
KouDy
Sun Oct 19, 2008 5:18 pm
#4 by KouDy
I have 64-bit version of ProgDVB on Win Vista 64-bit. If you have SP1 installed and 4GB ram it's only driver issue. Please refer to my post here.
  • Fri Apr 03, 2009 7:17 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 6:46 pm
