6.05.01 no signal + crashes
hello, everything was ok utill last update to 6.05.01
i get no signall and after exiting the prog crashes with this:
   at ()
   at ..()
   at ProgDvbNet.MainForm.(Object , FormClosedEventArgs )
   at System.Windows.Forms.Form.OnFormClosed(FormClosedEventArgs e)
   at IPDev.Skins.SkinForm.OnFormClosed(FormClosedEventArgs e)
   at System.Windows.Forms.Form.RaiseFormClosedOnAppExit()
   at System.Windows.Forms.Application.ExitInternal()
   at System.Windows.Forms.Application.Exit(CancelEventArgs e)
   at System.Windows.Forms.Application.Exit()
   at ..Execute(String cmd)
   at ..(String )
   at ProgDvbNet.MainForm.(Object , EventArgs )
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
ProgDvbNet
    Assembly Version: 6.5.1.0
    Win32 Version: 6.05.01
EngineApiWrapper
    Assembly Version: 1.2.6.0
    Win32 Version:
msvcm80
    Assembly Version: 8.0.50727.762
    Win32 Version: 8.00.50727.762
    CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
    Assembly Version: 1.0.2.0
    Win32 Version: 1.0.2.0
IPDev.Skins
    Assembly Version: 1.3.9.0
    Win32 Version: 1.3.9.0
ProgDvbNet.EPG
    Assembly Version: 1.0.5.0
    Win32 Version: 1.0.5.0
ProgDvbNet.CC
    Assembly Version: 1.0.4.0
    Win32 Version: 1.0.4.0
    CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CC.DLL
ProgDvbNet.Win
    Assembly Version: 1.0.0.0
    Win32 Version:
Accessibility
System.Design
System.Xml
System.Drawing.Design
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
if i revert back to 6.05, everything is ok.
winXP 32 + Gigabyte GT-P8000
now it work OK.
I change it to azure wave .
BTW when I install ProgDVB I usually choose azure wave, and
the mode is Auto in Device options , and in Device List BDA DigiGo .
