AF9015 BDA not working
1 post
galmok
galmok
Sat Dec 29, 2007 11:31 am
#1 by galmok
I had the AF9015 BDA device working with ProgDVB 5.16.2, but I simply can't make it work with version 6. The tuner is found by progdvb 6, and while it doesn't error, it only shows a black screen. Searching for channel, even blind search, is done in 1 second, not finding any channels.
Vista64, BDA driver from windows update.
  • Thu Jul 16, 2009 8:27 am
1 post
Return to “Hardware”
Из России и Нидерладов файл доступен. Пользователи пока не жаловались.
Prog, Thu Jun 04, 2026 5:44 pm
Качается... Какие то региональные ограничения? Если и есть, то с вашей стороны. Попробуйте через tor-browser!
Mostwanted, Thu Jun 04, 2026 12:24 pm
Prog, Thu Jun 04, 2026 12:13 pm
https://files4.progdvb.com/progdvb/ProgDVB7.71.5x64.exe
Mostwanted, Thu Jun 04, 2026 10:29 am
  • It is currently Sat Jun 06, 2026 4:25 pm
