Anysee E30 S2 Plus support?
sardonis
sardonis
Wed Jun 11, 2008 4:03 pm
#1 by sardonis
I was wondering if anyone got progdvb to work with the Anysee E30 S2 Plus
On the anysee website there is a plugin for Anysee cards SPlug.dll
http://www.anysee.nl/index.php?sct=downloads&file=64
I can't get it to work. I can see the device listed but I can't scan for channels..
  • Wed Jul 29, 2009 9:15 am
sardonis
sardonis
#2 by sardonis
I guess that's a no :roll:
  • Thu Aug 06, 2009 8:37 am
#3 by Prog
Do you use without diseq?
Same problem in scan transponder dialog?
  • Thu Aug 06, 2009 9:01 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:48 pm
