when im using the function to move a channel on rightclick i get the follogwing error!
System.Exception: GetControlNode from not correct tree
at ..( )
at ..(List`1 )
at ..InsertFromText(String text, node, Boolean after)
at ProgDvbNet.MainForm.(Object , EventArgs )
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
ProgDvbNet
Assembly Version: 6.11.7.0
Win32 Version: 6.11.07
CodeBase: file:///C:/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.2.12.0
Win32 Version:
CodeBase: file:///C:/ProgDVB/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50727.4016
Win32 Version: 8.00.50727.4016
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4016_none_d0893820442e7fe4/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.3.0
Win32 Version: 1.0.3.0
CodeBase: file:///C:/ProgDVB/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.3.18.0
Win32 Version: 1.3.18.0
CodeBase: file:///C:/ProgDVB/IPDev.Skins.DLL
ProgDvbNet.EPG
Assembly Version: 1.0.6.0
Win32 Version: 1.0.6.0
CodeBase: file:///C:/ProgDVB/ProgDvbNet.EPG.DLL
ProgDvbNet.CC
Assembly Version: 1.0.4.0
Win32 Version: 1.0.4.0
CodeBase: file:///C:/ProgDVB/ProgDvbNet.CC.DLL
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
CodeBase: file:///C:/ProgDVB/ProgDvbNet.Win.DLL
Accessibility
System.Design
System.Xml
System.Drawing.Design
enabled.
For example:
<configuration>
</configuration>
