I get following message when trying to change to some channels:
at ProgDvbNet.StatusBarManagerClass.( )
at ProgDvbNet.MainForm.( , )
at ..(ChannelNode , )
at ..(Point , )
at ..(Object , MouseEventArgs )
at IPDev.Skins.GUIChannelListView.OnNodeMouseClick(ChannelNodeMouseClickEventArgs e)
at IPDev.Skins.GUIChannelListView.OnMouseUp(MouseEventArgs e)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
ProgDvbNet
Assembly Version: 6.20.5.0
Win32 Version: 6.20.05
EngineApiWrapper
Assembly Version: 1.3.0.0
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.3053
Win32 Version: 8.00.50727.3053
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.4.0
Win32 Version: 1.0.4.0
IPDev.Skins
Assembly Version: 1.3.19.0
Win32 Version: 1.3.19.0
ProgDvbNet.EPG
Assembly Version: 1.0.6.0
Win32 Version: 1.0.6.0
ProgDvbNet.CC
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CC.DLL
System.Xml
Accessibility
System.Design
System.Drawing.Design
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
enabled.
For example:
<configuration>
</configuration>
Intel C2D E6600
Asus P5N-E SLi
ATi Radeon HD4890
2GB Corsair RAM
Terratec Cinergy C PCI HD
Windows XP Pro SP3
Uploaded a picture of my codecs if interested:
It also happened in the previous edition. And it takes me 3-4 seconds to make a channel change, tried different software like VLC, dvbviewer and the included terratec hc and they apparently change a lot faster...
However that's not my main "problem"
