Can we change subtitle align? I want centered subtitles.... This great program must have this, but I still cannot find how I can set this?
Thanks!
Thanks!
for now nothing, i will hope in the next version this option will be avalible
http://www.embedded-uptime-project.com/bild_1701_2200_1.jpg
I spend about hour to find this option, because I was sure that this option is there, and I just cannot find it.
OK. we must wait next version....
Thanks soulraven!
Thanks soulraven!
I find that, but no aligh
So you can add option, or use CENTER like in other programs and receivers (if You author of ProgDVB
Thanks Prog in advance!
? How you meen bad??? If you use MyTheatre, there is centered DVB titles. In most receivers, also titles are center, on films, other Tv stations in our countru - everyone use centered text.
What you ment wnen you say "It is bad in most situation."? Bad???
Thanks Prog in advance....
