    • Unanswered topics
    • Active topics
Version Info / Date
hawo69
hawo69
Thu May 28, 2009 7:07 am
Austria
Version Info / Date
#1 by hawo69
Pls. can you write down Date of Install / Version Info and so on
in the registry keys ?
e.g. SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
regards
  • Sun Nov 15, 2009 4:32 pm
May be in future...
  • Sun Nov 15, 2009 5:16 pm
Re: Error with scheduler in P…
Please describe the steps. Do you click “mark for record” and ProgDVB crashes? Or do you need to create 2-3 recording
John90, Sun Nov 09, 2025 9:36 am
Свой файл с тем же именем что и старые? Нет, свой файл с тем именем, кое у него было. Ааа... понял. Нужно положить
kostan, Sun Nov 09, 2025 8:36 am
Also check black background of video. For example, if the application window is narrow but the channel is 4:3. What are
Prog, Sun Nov 09, 2025 7:09 am
In logs total same mode... btw, do you have color changes in ProgTV interface? You can select black color scheme on both
Prog, Sun Nov 09, 2025 6:53 am
  • It is currently Sun Nov 09, 2025 10:59 am
