[ProgDVB 6.23.2] Some channels don't work
Hi,
at first i want to say, that my english isn't the best (I'm from germany). So sorry for any mistakes. ;)
I'm using a Hauppauge Nexus PCI DVB-S card with Windows XP Professional SP2 and have the problem, that just a few channels work no matter if the channels are on the same transponder or not.
I think the codecs are correctly configured (MPEG2: Power DVD 6.xx /H.264/AVC: ffdshow Codec).
I've used the channel search function and it find all the channels but most of them don't work. The antenna is absolutly ok. Two TVs are working on it without any problems.
Antenna is by Kathrein and is geared towards ASTRA 19.2E and EUTELSAT 13.0E.
btw.: I've used version 6.11.6 before without any problems like that.
Thanks for reply so far
Greetings
Jason
EDIT: And no, nearby is no DECT phone. ;)
Life sucks, but the visual effects are awesome!
