Hi there,
for weeks I try somehow to get HD via my TT Budget C-1500 card. With or w/o the elecard version of ProgDVB, it just doesn't work.
Is there somewhere an existing .xgr file for this card that allows me to watch HD ?
LET'S NOT TALK ABOUT THE ISSUE OF ENCRYPTION !!!!
I would just like to know if is it possible to watch HD with this card THEORITICALLY ! Did someone manage it ? And if yes how ?
I am desperate for any help !
Thanks
PS.: Star Wars rules !
only HD thats transmitted in DVB-S 1 standart (mpeg-2 or H.264)...Graphs are included in progdvb (Mainconcept and cyberlink...you have to install the codecs too
HD in DVB-S 2 standart is not possible with this card...
It is hopeless then, on cable there are only too HD channels are available both are probably DVB-S2. What a pity. I guess the codecs are more than enough times are installed ...
At the end I really have to go to the provider and buy the receiver if I want to watch it.
For cable aren't there any cards yet to receive HD, are there ?
Thanks for the info anyway !
Sorry to have to interfere...
DVB-S2 is satellite only.
There's nothing similar on cable, as the technical conditions are completely different there, QAM instead of *PSK, f.e.
So, at least for now, there's no magic new modulation on cable, that would require different tuner / demodulator hardware.
This means, normally all cable cards should be able to receive HD, if a suitable codec and enough CPU power available.
Though, of course content might be protected in several ways, not just for PayTV issues.
Complex DRM systems can forbid, to play out over analogue resp. unprotected ports, or limit to SD then, or block recording and more.
Ok guys, thanks for the replies, helped a lot. Everything seems normal, the "small lock" is green, the CPU is performing at 30%, codecs are installed and seem to work. It's probably really the rest of the blocking possibilities Juergen has mentioned.
Thanks again and Happy New Year !
