Skystar usb 2 hd ci with progdvb in win 7 32/64 - problem
hi ...
prog dvb 6.49.4
i have problem with bda and prog dvb in windows 7 32 &64 bit
i upload image for it ... plz help me
i install all driver and last driver from technisat site
i try 6.49.5 and same problem:(
i try reinstall and .....
plz help me
(note : i dont have any problem befor reinstall win7 64bit ... but when new install win7 64bit i have this problem:( )
Re: Skystar usb 2 hd ci with progdvb in win 7 32/64 - proble
Prog wrote:What message when you start module?
i cant start this modules ... becuse it is disable ....
and so no message ...but when enable this modules :
at ProgDvbNet.TvSources.EnableAction.Do()
at ProgDvbNet.AdvancedDeviceListForm.DoAction(Action act)
at ProgDvbNet.AdvancedDeviceListForm.ActionButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
ProgDvbNet
Assembly Version: 6.49.5.0
Win32 Version: 6.49.5
EngineApiWrapper
Assembly Version: 1.4.2.0
Win32 Version:
msvcm90
Assembly Version: 9.0.30729.4926
Win32 Version: 9.00.30729.4926
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_08e1a05ba83fe554/msvcm90.dll
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.1.2.0
Win32 Version: 1.1.2.0
ProgDvbNet.CD
Assembly Version: 1.0.2.0
Win32 Version: 1.0.2.0
CodeBase: file:///C:/Program%20Files/ProgDVB/ProgDvbNet.CD.DLL
IPDev.Skins
Assembly Version: 1.3.21.0
Win32 Version: 1.3.21.0
System.Xml
Accessibility
System.Design
System.Drawing.Design
ProgDvbNet.Win
Assembly Version: 1.0.1.0
Win32 Version:
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
befor reinstall window i can choose diseqc for LNB s ... and all were ok
but after new install windows i cant choose diseqc ... ( picture post 1)
