hi
in v 6.49.7 go to where diseq setting?i can,t find it for set diseq setting.
Re: Diseq setting?
#3Try removing the "DiseqTree.ini" file from ProgDVB folder. This will allow you to add a switch and LNB's.
Older version of "DiseqTree.ini" from previously installed versions of ProgDVB do not seem to work.
Make backups of any files you delete.
Re: Diseq setting?
#4thanks man,i,m delet this file but atall again have not any where for change DIDEQ SETTING or set motor setting,where is it going?jaffo wrote:Try removing the "DiseqTree.ini" file from ProgDVB folder. This will allow you to add a switch and LNB's.
