    • Unanswered topics
    • Active topics
Is Sandberg Mini DVB-T Dongle supported?
gartner
gartner
Wed Dec 01, 2010 8:42 pm
#1 by gartner
Hi
I wonder bay a MPEG4 dvb-t usb stick.
Is this one supported ?
sandberg.it/product.aspx?id=133-59
Or what other usb tuner do you recommend??
regards
gartner
  • Wed Dec 01, 2010 8:46 pm
riki
riki
Mon Dec 27, 2010 6:35 am
Re: Is Sandberg Mini DVB-T Dongle supported?
#2 by riki
You want to support Sandberg Mini DVB-T Dongle on what? You want to support it on your computer or laptop or in your screen whatever you use. Anyway there are a lot of usb tuners available in the market today. Make sure you type what you want and just get it from the shop the compatible model.
hhgregg
  • Mon Dec 27, 2010 6:37 am
Return to “Hardware”
You can try prerelase of ProgDVB.
Prog, Mon Dec 15, 2025 4:53 pm
I am not download this list. Really huge list. I change your password in list and use it as crash test:) ProgDVB very sl
Prog, Mon Dec 15, 2025 7:39 am
А лучше ссылку на канал. mkv/mp4 неудобные форматы для записи и всегда будут отличаться тем, что работать хуже чем TS. П
Prog, Mon Dec 15, 2025 7:10 am
running raseberry tv on progd…
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s
prop, Sun Dec 14, 2025 11:59 pm
  • It is currently Tue Dec 16, 2025 10:24 am
