ProgDVBEngine.dll crash in 6.49.09 - Windows Vista
I checked the event viewer in Vista today after ProgDVB crashed, and this was what it listed:
Log Name: Application
Source: Application Error
Date: 17/12/2010 11:03:14
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: ANOther-PC
Description:
The description for Event ID 1000 from source Application Error cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
ProgDvbNet.exe
6.49.9.0
4d022713
ProgDvbEngine.dll
0.0.0.0
4d02271e
c0000005
00033dfa
The substitution string for insert index (%1) could not be found
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-12-17T11:04:14.000Z" />
<EventRecordID>39044</EventRecordID>
<Channel>Application</Channel>
<Computer>ANOther-PC</Computer>
<Security />
</System>
<EventData>
<Data>ProgDvbNet.exe</Data>
<Data>6.49.9.0</Data>
<Data>4d022713</Data>
<Data>ProgDvbEngine.dll</Data>
<Data>0.0.0.0</Data>
<Data>4d02271e</Data>
<Data>c0000005</Data>
<Data>00033dfa</Data>
</EventData>
</Event>
What could cause this? I ran an anti-malware scan, no viruses were found, so what's causing this?
I also run this under compatibility mode for Windows XP, for the record.
