Hi,
I have installed W7x64 and I use the ProgDVBx64.
When I copy a plugin into the ProgdVB-Folder: Plugins, ProgDVB can't found them.
They say: No plugins
If I use a ProgDVBx32 the plugins works fine.
Is there a problem with ProgDVBx64 and plugins?
MLZ
Re: ProgDVB x64
#2Please read Manual-> FAQ about that.
ps: You can use both version with same license.
Re: ProgDVB x64
#3Prog wrote:Please read Manual-> FAQ about that.
mean work fine 32 plugin in 64 version?
Re: ProgDVB x64
#4I would think NOT. 64 bit version requires 64 bit plugin (and 64 bit codecs)sky star 2 wrote:Prog wrote:Please read Manual-> FAQ about that.
Chris.
Re: ProgDVB x64
#6What problem? About plugin? You can use x32 versions of dlls only in x32 application. it is limit of win architecture.
Re: ProgDVB x64
#7Prog wrote:What problem? About plugin? You can use x32 versions of dlls only in x32 application. it is limit of win architecture.
don,t work vPlug,hadu,acamd ... in 64Bit prog.but work very good in other players in 64 bit.looklike dvbdream,dvbviewer and other but prog no?!!!
Re: ProgDVB x64
#9Prog wrote:Do you have x64 version of dream?
how must solve it?
