Prvg software that green bar that famous quote s Time Shift Buffer and broadcast images that push on a lever s s her film back and forth when you do you start recording a red line starts to move, which makes S record shows s
Now the question Prvg new versions (for example, that the final version) When do you start to record her Ahrmh the film back and forth does not do you act when I want back again So Hmvnjayy move the red line is if you Zbttvn older versions Was not comfortable doing this record was his own work and leverage your face Mytvnstyn while recording movies anywhere Bbryn
Why did this case a solution there, or the same old versions should work with it
S my current version 6.61.02
Prvg I want my movie with wmv format but when I start recording the first record looks like the same mpeg does capture one second and after a few seconds to start recording makes it even means that the red lever to move now and makes the active record, but Volume goes to show that file to record a few seconds it s 0 solution to this problem there as well as image capture during tick tick s course and sign the form is annoying and is very gentle film means that s S after recording something you would see that these get resolved tick
Thank you
Re: help me plz
#2I don't understand anything...
"s s her" ???
"S record shows s" ???
"her Ahrmh" ???
"Hmvnjayy" ???
"Zbttvn" ???
"Mytvnstyn" ???
"Bbryn" ???
Never ever read that, and my dictionary does not help at all...
Do you use a machine translator?
If so, you MUST type in totally correct, as else the software does not give any useful results.
And perhaps try to re-translate the output to your native language, to see what happens...
Or maybe you're just in need of a new keyboard...
"s s her" ???
"her Ahrmh" ???
"Hmvnjayy" ???
"Zbttvn" ???
"Mytvnstyn" ???
"Bbryn" ???
