Hello
I like this program but i have aproblem with diseqc
i have 2 satalite(nilesat and hotbird) in a 4 ports diseqc
the problem is that there is many frequancies in both satalites like(11296 in hotbird and 11938 in nilesat) can not working when i use the diseqc
if i remove diseqc and make it direct to lnb nilesat or hotbird and put one satlite the all frequancies of sat work correctly
so i think there is problem with azurewave bda device
help me
thaanks
Re: azurewave 7022 dvbs box diseqc
#2BDA driver? Check Settings->Device options./ azurewave should be selected.
#3yes bda driver
and azurewave/twinhan selected
but the problem still exist
#5i tried everything in device options but nothing changed
i think its bda device problem because I use smartdvb and every thing work 100%
#6finaly when i install progdvb 6.33 everything work good and all freqs work fine
so i sure its bda device problem
#8thank you
i did that and progdvb 6.61.3 now work fine without any problem and everthing ok
#9Hm. But can you make some experiments with BDA module settings in last version?
#10there is no options in device options after i copied bda and ebda device
but the only thing i did is choose azurewave/twinhan in device options
How i can make other options appear?
#12there no check box
i attached device options image
- Untitled.jpg (13.58 KiB) Viewed 16747 times
#14this is the last version of progdvb 6.61.3
but device options appear like this because i copied the older bda and ebda device
#15i hope you modify bda and ebda in the next version like the older one but with device options choices
because i can not found diseqc repeat times after i copied the older bda and ebda in the last progdvb version folder
