I am using win7 64bit and watching channels thru internet when i try to play some TV or radio stations the program crashes: (Progdvb stop working, a problem caused the program to stop working correctly windows will close the program and notify you if a solution is available.)
Some channels do not show up despite the bar which showing the L and Q is 100%
Pls. what is the solution?
Re: Program crash always, using win7
#3Hi I also have a problem with prog DVB crashing when listenuing to satelite radio stations. It runs very well for two hours or thereabouts then stops working with the messaged "Prog dvb has stopped working, windows is searching for a solution..."
Windows 7 professional 32 bit
AMD Phenom II x4 810 processor
4GB Ram
Prog DVB 6.70.06 ( It happens on previous versions as well )
Skystar 2 PCI version 1.31
Many thanks in Advance.
4GB Ram
#5Hi, Thanks for the quick reply. Not much in the logs file so I have included one of the windows dmp files.
Brgds
Brgds
#7Hi Thanks for the tip.
Please find attached the log files.
Have a great day and thank you for the excellent support.
- Logs.zip
- (156.06 KiB) Downloaded 1993 times
#9Hi,
Log is after crash. I think problem may be related to windows power management. My power management is set to turn off screen after 2 hours, sleep after 3. I havent watched closely enough which one it is. I will try again next thurs or friday.
Thanks
Thanks
#10ProgDVB must block sleep function of OS. (if this option enabled)
#11Hi, I havent had the problem for some time. I believe it is due to the time shift buffer full. I have now increased the buffer size to 2000Mb which is more hours than I listen to and the problem has not re-occured.
Brgds
Brgds
