WinTV-Nova-T (USB) Stick and WinTV-Nova-HD S2 (PCI) card
meinertreu74
meinertreu74
Sun Oct 02, 2011 12:05 am
#1 by meinertreu74
Hey!
I have both devices installed on an Windows 7 x64bit computer with the newest drivers from Hauppauge (BDA-driver). I have checked and seen that the wintv-nova-HD-S2 pci-card are not supported with Progdvb v. 6.72.
The WinTv-nova-T usb-stick works, but not fine.
What can I do?
I hope for help.
send friendly regards
meinertreu74
  • Sun Oct 02, 2011 12:36 am
Re: WinTV-Nova-T (USB) Stick and WinTV-Nova-HD S2 (PCI) card
do you test ProgDVB x32 ?
  • Sun Oct 02, 2011 12:56 am
meinertreu74
meinertreu74
#3 by meinertreu74
hey prog.
yes, i have test ProgDVB x32 (32bit) too. Its the same issue.
  • Sun Oct 09, 2011 7:03 am
#4 by Prog
But, how it looks? Do you have some error message?
  • Sun Oct 09, 2011 7:11 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:50 am
