Skystar S2 PCI problem of detecting
rsobczynski
rsobczynski
Fri Oct 28, 2011 7:50 pm
#1 by rsobczynski
Hi i have Windows XP Profesional and install Skystar S2 PCI card but no version of ProgDVB not detect this card??
Did anyone had this problem???
I use 4.6 tehnisat new driver WDM
Thanks for help
  • Fri Oct 28, 2011 8:00 pm
Re: Skystar S2 PCI problem of detecting
Try install software from CD for registration of all libraries.
  • Sat Oct 29, 2011 11:50 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:40 am
