Hello,
i have a nova-s plus and on prog dvb 4.8.0 i have chose the BDA DVB-T Antenna device. is the new version full nova-s plus compatible, so that i'm have not to chose the BDA dvb-t device? Because the channel search do not found the premiere channels.
as you can read xxx times in this forum...this not depends on progdvb ...its depends on your registry settings...
							this is a card that runs on bda driver ...as others cards running on bda drivers too ....choose the DVB-S bda device in progdvb device list...
If there is no such device in the list...exit progdvb ...
then save this :
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Tuning Spaces]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Tuning Spaces\1]
@="{B64016F3-C9A2-4066-96F0-BD9563314726}"
"Name"="TT-DVB-S"
"Description"="DVB-S"
"Network Type"="{FA4B375A-45B4-4D45-8440-263957B11623}"
"Frequency Mapping"="ex:2d,00,31,0"
"System Type"=dword:00000002
"Network ID"=dword:ffffffff
"High Oscillator Frequency"=dword:00a1be40
"Low Oscillator Frequency"=dword:0094c5f0
"LNB Switch Frequency"=dword:00b28720
"Input Range"="ex:2d,00,31,0"
"Spectral Inversion"=dword:00000002
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Tuning Spaces\1\Default Locator]
@="{1DF7D126-4050-47F0-A7CF-4C4CA9241333}"
"Frequency"=dword:00b7e238
"InnerFECMethod"=dword:ffffffff
"InnerFECRate"=dword:ffffffff
"OuterFECMethod"=dword:ffffffff
"OuterFECRate"=dword:ffffffff
"ModulationType"=dword:00000014
"SymbolRate"=dword:00006b6c
"Polarisation"=dword:00000002
"OrbitalPosition"=dword:00000000
"Azimuth"=dword:ffffffff
"Elevation"=dword:ffffffff
"WestPosition"=dword:00000000
as xyz.reg...double click to import into windows registry and try again in progdvb
viewtopic.php?t=27Because the channel search do not found the premiere channels.
if you can't find all channels or can't make ascan or whatever ...
here is another way ....
you can build your channel list by yourself very easy:
ex: from auto.satcodx.com there you can make your list what you want.
(there is a nice generator tool.)
1.) ProgEdit - import the SDX list from auto.satcodx.com
2.) fill out the missing values on Device Infos" (take the values from your old channel list)
3.) overwrite PPV channels with the "overwritechannels" function for correct PW channels names.
4.) save it - have phun
cu camel
cu camel
