SkyStar 2 pci low signal
fancy
fancy
Fri Aug 26, 2011 11:35 pm
#1 by fancy
hi..i have skystar 2 pci card and i'm getting low signal with all channels
i had included a scrennshot below
any help?
  • Tue Nov 29, 2011 6:29 pm
fancy
fancy
Re: SkyStar 2 pci low signal
#2 by fancy
when i use dvb dream i'm getting a better signal
see screenshot
how to solve this problem?
  • Tue Nov 29, 2011 6:51 pm
#3 by Prog
You must compare lost of packets.
ps: I can make version for show 200% for all devices :)
  • Wed Nov 30, 2011 8:16 am
fancy
fancy
#4 by fancy
that signal reading doesn't bother me at all coz the channels are working properly
i just wanted to know why the signal is not the same in progdvb & dvbdream? :)
here is another example with 0 packet loss
  • Wed Nov 30, 2011 5:38 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:40 am
