I have lag in application menu. Mouse moves ok, but to select something / push any button has about 1sec delay.
My system:
OS: Win7 64 bit SP1 Home premium
CPU: 2.66Ghz dual core
Video: GeForce 450 GTS 1GB
RAM: 8GB
TV/FM tuner: Hauppauge 3000 HVR.
Can it be that tuner is not fully compatible with your software ?
Re: ProgDVB x86 6.80.02 Menu lags
#3Top list menu , right mouse click menu.Prog wrote:What menu you mean? Is it depended from video renderer?
Menu lag do not depends from video renderer.
#5I use ProgDVB to watch DVB-T TV channels. If i press right mouse button on any place in video window (while i watch any TV local TV channel) it has delay about 1sec.
*When ProgDVB do not streaming video - I don't have menu lag.
*With internet TV / radio this issue is not reproducable.
#6change nvidia driver, maybe this one has to do with it.
for me, right click or top menu has zero lag.
#7This issue is related with Hauppauge 3000 drivers, it has nothing to do with nvidia drivers.reeven wrote:change nvidia driver, maybe this one has to do with it.
Because if i disable device - i don't have menu delay.
To fix this issue i think ProgDVB <-> Hauppauge developers should work together.
#8i am not not have any contacts with hauppauge
But problem not in hauppage driver.
ps: Please send me logs files of this moment.
#9Where it saves log file and how it is named?
Menu lag has not only ProgDVB.
Even bigger menu lag (about 2.5sec) has Blazevideo HDTV Player Professional 6.6 ...
Win TV 7 CD2.4 works ok.
#11ok.Prog wrote:Settings->Options->Debug->Logs at first
I marked there "logs". But where it will save the file?
In C:\Program Files\ProgDVB ?
#13ok. I uploaded logs.
- Logs.zip
- (58.96 KiB) Downloaded 467 times
#15Thanks for care, i think i can live with this delay.
It is not that big like in Blazevideo HDTV Player Professional 6.6 anyway
*This topic can be terminated.
