I use the SkyStar 2 HD PCIe on Win7x64.
But the Remote Control of this device does not work with my ProgDVB pro (or i have not yet make it to work)
So I want to know if it possible with the device-Remote or witch Remote Control I can buy. perhaps one who work with the MCE of Windows
Re: Remote Control
#2You must use the WDM driver. For BDA SS2 driver Remote Control is not supported.PAddy653 wrote:I use the SkyStar 2 HD PCIe on Win7x64.
Re: Remote Control
#4WDM: Device manager section Network AdapterPAddy653 wrote:if I select "SkyStar 2 (WDM)" i got an Error "Device not Startet!"
BDA: Device manager section Sound Device
Need install wdm driver.
Re: Remote Control
#5And how I install this driver?
I have delete the BDA-Driver an reinstall the driver/software from techniSat but it install everytime the same BDA!
Re: Remote Control
#61. Download last driver http://www.technisat-daun-fs.de/assets/ ... hd_001.zipPAddy653 wrote:And how I install this driver?
2. Unzip.
3. Update driver and manual install WDM from device manager.
Re: Remote Control
#8have allready install it manually! But everytime the same - BDA-Driver
Witch file must i select for the WDM-Driver?
Re: Remote Control
#9Did you uncheck show only compatible device at last step manual instal driver?PAddy653 wrote:have allready install it manually! But everytime the same - BDA-Driver
Need choose device "TechniSat SkyStar 2 eXpress HD".
Re: Remote Control
#10yes I have!
There are:
Cypress Bridge (BDA)
TechniSat DVB-PC TV Star PCI (BDA)
TechniSat DVB-PC TV Star USB 2.0 (BDA)
TechniSat DVB-PC TV Star USB HD(BDA)
TechniSat SkyStar 2 eXpress HD <<
TechniSat SkyStar 2 eXpress HD DUO
And the Driver is alway in Audio-. Video, Gamecontroller!
What I'm doing wrong?
There are:
Re: Remote Control
#11Please attach screenhont device manager after install "TechniSat SkyStar 2 eXpress HD" and screenshot properties of files driver(dblclick on device->driver->information)PAddy653 wrote:yes I have!
There are:
Re: Remote Control
#13Yes i'ts information right. And i see you have x64 windows, and have installed BDA version driver.PAddy653 wrote:I hope I have found the right-Information (because of German)
Try install device from catalog NDIS.
Re: Remote Control
#14Now I've a second Driver "TechniSat DVB-PC Virtual Network Adapter"
But the Device is not found.
Re: Remote Control
#15Did you install last version ProgDVB x64?PAddy653 wrote:Now I've a second Driver "TechniSat DVB-PC Virtual Network Adapter"
P.S. Maybe under Windows x64 Remote Contol not work. Try install DVB Viewer TE from originall disk and test Remote Control.
