Hello,
unfortunately progdvb does not work currently with the card.
when will the card supports from progdvb.
thanks...
lex
Re: Technotrend TT-premium S2-6400 twin hd
#2I just got my system set up and working but have been pulling my hair out trying to get my TT 6400 card to scan channels. This card doesn't work??? I also need support for this card.
What software does work with this card?????
Thanks
Thanks
#4Is there anything that can be done on my end to help?Prog wrote:This is very exotic device and I am not have sample.
#5I have the the same problem.
The card don't scan channels. Has nobody more experience with this card?
Is the support of this card in work?
#7I have tried some different device options but i have no possibility to select the original device (TT-6400).
When I use the BDA DVB-S Device option, the card doesn't scan.
#8tamtrix wrote:I have tried some different device options but i have no possibility to select the original device (TT-6400).
Did you use the bda driver from the tt hompage for the card?
Which version of progdvb is installed?
#9I use the TT-BDA driver for this card. ProgDVB version is 6.87
#10Maybe you can try the newest version (6.91). It should work with the latest BDA drivers but I have read
that the card has a hardware decoder. There are problems with this decoder???
#11Hi together,
i´m new. Nice to hear that i´m not the only one which have buy this card.
I would be very interested to youse an alternative program like Progdvb.
Has anyone experience with the compatibility between Progdvb and the S2-6400
or is there something in work??
#12It seems no one else has been able to get it to work either. I don't know much about programing but I would have thought that a hardware card would be easier to work with software since the card is doing all of the work. I would have thought all that needed to be done would be to pass the output from the card to the software and that the cards drivers would handle that. Is there anything I can do to help with getting this software to function with the 6400 card? Do you have some sort of card scanning software I could run that would give you information to aide in programming? I would very much like to get some use out of this expensive paperweight I bought.
#14A long time has been passed and the card is not longer supported.
Someone new insights???
#15I wish there was. I guess I have a $300+ paperweight. The Technotrend software is useless and no one else seems to make software that supports it. ProgDVB doesn't seem to want to support it either.
Any chance of support????????
