prog dvb crashing not responding
hi I have two os on different drives win xp and win 7 and progdvb on both is unreliable it crashes locks up and sometimes stops responding and even task manager cant kill it.
it wont move my h-h dish.
I have to set it as no satellite and move the dish with prog finder and even that constantly locks up not responding. and its usals is way out compared to my echolink sat receiver usals.
I have a tbs8920 pc card and a h-h motor.
I am trying to use 6.6309 and only have 12 days left of evaluation and doubt I will purchase it on the way it keeps locking up.
how can I use prog dvb to move my dish? the menus are not very friendly. how do I access the diseq 1 usals menu?
thanks
Re: prog dvb crashing not responding
thanks for that prog,
right I managed to set up 5 satellites on a positioner and it would move the dish from one satellite to the other now and then. other times It would freeze and say not responding. other times it would move but the picture would be black.
now it is stuck on astra 2. it wont move to other satellites.
prog finder will move it.
how do I access the logs?
thanks
aljolson wrote: how do I access the logs?
Settings->Options->Debug&Repair->Logs (Check on)
