Channel list lost after unproperly shutdown.
1 post
trilobit_cz
trilobit_cz
Sun May 12, 2013 6:04 pm
#1 by trilobit_cz
Hello,
i would like to ask you for helo. ProgDVB 6.92 Proffesionall x86 version in 64bit W7. After unproperly shutdown of my computer i lost my last channel list. There is old channel list with one sat. position. I worked hard for customize my channel list through whole day and now the channel list is gone. Thats pity and i am really angry :) Please can somebody tell me what happen and am i able to change it back ?
Thank you.
  • Sun May 12, 2013 6:20 pm
1 post
Re: IPTV EPG using Xtream Code
Also data of guide quick deprecate also.
Prog, Thu Apr 02, 2026 11:00 am
Do you try disable remove guide? Local guide not best solution. For example time of file deprecates relative to referenc
Prog, Thu Apr 02, 2026 10:59 am
I mean in options I post my local guide.xml link. eg.D:\Guide\guide.xml Then in TV Sources I pick Xtream code which has
Retrorat1, Thu Apr 02, 2026 8:22 am
Do you mean local file with guide? Try setup link to guide.
Prog, Thu Apr 02, 2026 7:07 am
  • It is currently Tue Apr 14, 2026 12:53 pm
