This problem comes with 6.94.5, updated yesterday. When I run ProgDVB and channel should start playing, I heard only sound, but video window is black.
If I run same channel again or I change channel to channel from SAME TRANSPONDER, I can watch video too.
So, problem exist also when I run DVB-T channel and after that I run channel from IPTV or I run IPTV channel and want run channel from DVB-T. There is no matter do I run same channel or some else (some channels are same in DVB-T and IPTV).
This problem not exist in 6.94.4 and earlier. Video starts playing every time and in every conditions.
Re: 6.94.4->6.94.5 - no video when starting ProgDVB, only au
#3Here it is.
- Logs.zip
- (95.22 KiB) Downloaded 274 times
#4try change audio codec or disable audio processor or change audio renderer. Audio part of graph not created.
#5Strange, I have problem with video and I should change settings related to audio.
I tried everything with audio settings, but nothing helped. Also tried change demultiplexor.
So I decided touch something related to video. I tried change video renderer and video works with Enchanced video renderer, VMR-9 (requires directx) and VMR-7. Others renderers not start video when starting ProgDVB.
It seems I find solution.
#6It is only quick hint after read your log. After more tests I will prepare test version of your.
#8No changes.
- Logs.zip
- (83.06 KiB) Downloaded 285 times
#9Please try "c" prerelease aslo.
What you do for this bug? Only open channel?
Custom EVR?
Custom EVR?
#11Yes, I only open channel.Prog wrote:Please try "c" prerelease aslo.
Custom EVR?
And yes, bug exist also with Custom EVR.
But good news - with nevest version (5e) problem is fixed!
