Can you help as to activate or to do this command?
"if you don't need to watch TV on server, start ProgDVB with the key /NoGraph to spare a great deal of resources"
Thank you
Recording Don't work with /NoGraph
#3Hello,SiLencer wrote:Make a shortcut of the server progdvb.exe and add this as a command line parameter
Recording don't work with "/NoGraph" Parameter in ProgDVB 5.12 Standard
With ProgDVB 4.84.2 it work fine.
Is there a solution for this?
Retest:
- Start ProgDVB 5.12 Standard with no parameters.
- Start Recording: Everything fine.
- Stop Recording
- Quit ProgDVB
- Start ProgDVB with /NoGraph parameter
- Start Recording: The recording button is grey, but no stream is recording.
- Stop Recording would not work.
#5Hallo,Prog wrote:Use async. mode of record.
thanks for your fast answer.
Where can I set async recording? Is this a command line switch?
I can find under Settings -> Options -> Record:
- Destination directories
- split file by size
- split file by time
- do not write file smaller
- record format for tv channels
MKH
On 4.88w8x it's this way:
menu item File --> TimeShift buffer status
Or simply by clicking the little clock symbol in the status bar--> ~
Should be similar on other versions.
Hello,Juergen wrote:Omn 4.88w8x it's this way:
I tested it.
The result was the same as before
TestOS: Windows XP Prof. with SP2 and Windows 2000 SP4.
I think this is maybe a solution but it's not my solution
MKH
HelloJuergen wrote:Omn 4.88w8x it's this way:
I have tested it in a lot of configurations. no way.
the only way its work is not to start with /NoGraph and instead to set the codec to "by graph"
this is no nice solution.
how can i help you to figure out a better way?
MKH
