hello
i have problem freezing when i exit progdvb .
other problem cant open two channel in same time . ( i try last 4 version x64 and x32).
this problem disappear on dvbdream but i cant use it because i used progdvb more than 4 years
i wish you can help me
my card tbs5990 ( dual tuner) usb
system : win 8.1 64bit
cpu : core i7 4700hq
ram : 24gb ddr3
gpu : gtx 780m 4gb
progdvb tv source
i
Re: freezing problem and cant watch two channel on tbs5990
#3what logs you need ?? more explain please
#5i do like you say and i selected logs option but nothing happen i still have freezing problem when i close progdvb and cant open two channel in same time .Prog wrote:Options->Debug->Logs
#6But send me logs after this situation.
#7that's logs file you need ?
i upload all logs file in on this links
download form her :
http://www.up-00.com/?75Oq
or :
http://www.4shared.com/zip/j2GQBYOuce/logs.html
or her :
https://mega.co.nz/#!g9IllJyD!FImsrL2So ... XAB5IiWGvA
or her :
http://b.fsend.net/recv2.php?a=bbr77m5krc
download form her :
or :
or her :
or her :
#8Please not post long messages.
1. Try both free channels.
2. try change video renderer to VMR9.
#9sorry for long postProg wrote:Please not post long messages.
i try many time with free channel and i try all video codec but nothing happen . you should have that new device TBS5990 and test it on progdvb
#10Not video codec. I mean video renderer (same page of settings in ProgDVB). Custom EVR request more resources then not custom.
#11i know this the first thing i did it but nothing happen the problem not solveProg wrote:Not video codec. I mean video renderer (same page of settings in ProgDVB). Custom EVR request more resources then not custom.
#12Do you have same problem if select Microsoft in Settings->Device options?
#13yes i have same problem .. you should have tbs5990 and test it becasue its new device in market i talking with tbs support and they tell me the problem form progvb not stable on tbs5990 .Prog wrote:Do you have same problem if select Microsoft in Settings->Device options?
#14In Microsoft mode ProgDVB use device like any other BDA device.
#15actually you don't have any solve to my problem .
i'll never do any new try with progdvb make freezing may lead to damage my device tbs5990. i will keep working with dvbdream
