Hi all,
i have a dvb card with 2 tuner.
With progDVB i have an issue: when i decide to choose a channel selecting it not form the channel list with the mouse, but using the keyboard number pad, on progdvb it open a list of more and more channels, and often it is selected the wrong channel, while i just want that the only channel with an associated channel number are the 15-20 channels i use in may personal channel list. And this situation cause also another issue: if channel automatically selected from the long list is on a different channel list, progDVB also change the channel list on the sidebar.
So the question is: how can i delete the channel number association to all channels but them in my personal channel list?
Many thanks.
																																							Re: Channel numbers issue
#3Great. The first proposal is the answer i was looking for.
But i'm not sure i understood the second suggestion: what "check "global search" in channel list properties" would be useful for? And anyway, i don't see that option in "channel list properties". I see:
Compact style
show satellite positions
show channel number
Local search by channel number
Below i have 3 box checked (tv, radio, other).
Compact style
show channel number
#4hi , i have kinda same problem changing channel with number from keyboard will switch to different channel list (satellite). for example im on hotbird list and watching a channel from hotbird and i want to switch channel number 1 on hotbird i press number "1" but it show channel name number 1 from YahSat and switch to yahsat, its confusing. just saying thanks.
																					Windows: 7 Service pack 1 , 32bit   _-_   DVB: Sky Star 2.8a PCI   _-_   CPU: 2.6 GHZ Dual core X2 AMD   _-_   RAM: installed 4Gig , 2.75 Gig usable  _-_  Graphic: ATI Radeon x1200 series total available memory : 1663
#6there is no global search in channel properties :Prog wrote:Then global search enabled in channel list properties.
#8um yeap!Prog wrote:In all 3 list?
where exactly is global search? i right click on a channel and from the opened menu last item is "channel List Properties" and when i open it there is no global search as you can see in picture i've sent in previous post.
#10this is dowload link of my channel directory: http://p30up.ir/images/n6lscxgqajn8ojof32k.zipProg wrote:Please send me you channels directory for test.
#11Ops. Options have name "local search" and must be checked for you. Or?
#12LOL ! problem solved by selecting this option for all 3 channel list
#13Seems to be a good setting also for me: the one about channel number was the solution for the major problem, but also delating channel number from other lists, i had in some case the channel list switch issue. Now also the lists switch seems to have gone. I just need to do a longer check to be sure.
Thanks again.
							Thanks again.
