Just a heads up to those that update to 10074 as there's something funky going on..
I tracked it down to the video renderer.. More specifically ProgDVB will crash on anything other than VMR-7 & Video Renderer. If you select VMR-9 & Enhanced Video Renderer, it'll crash.
Further investigation shows that 10074 has directx 12... and even when installing dx 11 runtime, it still crashes..
Re: Windows 10 x64 10074 Crash
#5Thanks.. I already found the logs folder in the progdvb folder, but it's empty..
Perhaps progdvb crashes before it can dump the log..
#6Narrowed it down a bit more.. Apparently the AMD drivers supplied with 10074 are crippled.. Uninstall the supplied drivers and install the win 8.1 drivers..
