PC crash, unfortunately...
With last version. 7.16.0a/b/c/e
So, hardware section and crash...
What to do?
Windows 10 Pro 64 bit, licenced.
With DVBDream v3.0, work ;
Re: GENIATECH MyGica USB stick DVB-T2 device ( T230 driver )
#18My master,
After progdvb established; first start progdvb open.
Selecting hardware and PC crash.
I do Restart PC
Second start progdvb, pc direct crash.
I do Restart PC
After; third, fourth... always crash.
Accordingly, How do I get logs.
To overcome the problem; remove progdvb
and new install.
But the first choice at hardware, crash again.
So, do not look my opportunity to receive logs.
I do Restart PC
I do Restart PC
and new install.
#19You can install ProgDVB without device setup, enable logs and enable device back.
#22I am not have good ideas about your log (is it crash or simple exit?) but try remove geniatech.ebda file
#23Again, unfortunately crash ... ( remove while "Geniatech.eBDA" )
This problem; is it possible to originate from windows 10 ?
I try, USB 2.0 and USB 3.0 ports. The results did not change.
What else can be done ?
#24I am not have same reports from other users. But not many users have same device. May be some other driver? For example from device with same chip.
#25I tried two different drivers, again.
Previous ; 1.31.1145.0
Last ; 1.33.202.0
Unfortunately, the results did not change ...
From the PC TV card is not inserted in another.( Only Geniatech inserted. )
Card at the time of selection, crash.
I could not do this problem.
Total Media ; work
DVB Dream ; work
Last ; 1.33.202.0
Total Media ; work
DVB Dream ; work
#26Tv sources ;
[BDA] Digital TV section and PC crash.
This section file ; Modules/BDA.Device file.
If this file exists, the TV card is displayed.
If file does not exist, it can not be displayed.
So, problem; BDA.Device file. ( According to my tv card ... )
#28Also no one other software not can use BDA in same time.
#291. No. I use pro 32/64 version( ProgDVB + ProgTV Professional for x32/x64 OS )Prog wrote:
1. btw, do you try ProgDVB x64?
2. Also no one other software not can use BDA in same time.
2. ProgDVB when I run; just run ProgDVB. I checked "Task Manager"
- At PC also; Arcsoft Total Media and DVB Dream Installed. And normal work.
#30x64 is only experiment. You can install to c:\progdvb in portable mode for test.
