Re: GENIATECH MyGica USB stick DVB-T2 device ( T230 driver )
#38
acoloss wrote:hi,
just to let you know, i have the same stick and same crash on windows 10 progdvb7
when i tick the "BDA.." in TV Sources, get BSOD
Hi mate,
Thank you for your be an observer.
Unfortunately still BSOD...
Win8.1 same error.
In the locality I live, the channel names are "cyrillic alphabet"
Other DVB players do not support "cyrillic alphabet".
So, channels names look like this ;
That's why I wanted to use ProgDVB ...
But it seems like there is no solution for now.
#45
İnside "ProgDVB" folder ;
Channels\	<DIR>	14.10.2016 22:48	----
ChLogos\	<DIR>	14.10.2016 22:48	----
Filters\	<DIR>	14.10.2016 22:48	----
Microsoft.VC90.CRT\	<DIR>	14.10.2016 22:48	----
Modules\	<DIR>	14.10.2016 22:48	----
Plugins\	<DIR>	14.10.2016 22:48	----
Record\	<DIR>	14.10.2016 22:48	----
RemoteControl\	<DIR>	14.10.2016 22:48	----
Skins\	<DIR>	14.10.2016 22:48	----
Themes\	<DIR>	14.10.2016 22:48	----
Transponders\	<DIR>	14.10.2016 22:48	----
tr-tr\	<DIR>	14.10.2016 22:48	----
TvSourcesTemplates\	<DIR>	14.10.2016 22:48	----
Vis\	<DIR>	14.10.2016 22:48	----
ChannelNameTable.txt	2.289	15.07.2015 15:39	-a--
CityList.txt	260.557	26.10.2012 12:45	-a--
credits.txt	1.179	14.10.2016 20:28	-a--
EngineApiWrapper.dll	223.432	25.11.2016 13:28	-a--
GuideStyles.txt	5.644	02.11.2012 21:19	-a--
help.chm	197.815	22.02.2011 13:15	-a--
install.log	18.990	25.11.2016 17:25	-a--
Installation.ini	200	25.11.2016 17:24	-a--
Ionic.Zip.Reduced.dll	205.000	25.11.2016 13:28	-a--
IPDev.SkinEditor.Design.dll	99.528	25.11.2016 13:28	-a--
IPDev.Skins.dll	562.376	25.11.2016 13:28	-a--
presets.txt	861	10.07.2014 17:25	-a--
ProgDVB.Common.dll	72.904	25.11.2016 13:28	-a--
ProgDvbEngine.dll	5.849.800	25.11.2016 13:29	-a--
ProgDvbEngineRun.exe	114.888	25.11.2016 13:31	-a--
ProgDvbNet.exe	1.378.504	25.11.2016 13:28	-a--
ProgDVBNet.Base.dll	92.872	25.11.2016 13:28	-a--
ProgDvbNet.bc.dll	205.000	25.11.2016 13:28	-a--
ProgDvbNet.CD.dll	2.153.672	25.11.2016 13:28	-a--
ProgDVBNet.EPG.dll	212.168	25.11.2016 13:28	-a--
ProgDvbNet.Win.dll	86.728	25.11.2016 13:28	-a--
ProgDvbService.exe	33.992	25.11.2016 13:31	-a--
ProgDvbService.exe.config	134	25.07.2016 02:10	-a--
ProgGuide.exe	132.296	25.11.2016 13:28	-a--
ProgLauncher.exe	401.608	25.11.2016 13:31	-a--
ProgTV.exe	1.340.104	25.11.2016 13:31	-a--
ProgTV.exe.config	238	25.11.2012 12:09	-a--
ProgTvStrings.txt	6.847	16.12.2012 13:18	-a--
ProvidersEngine.dll	467.144	25.11.2016 13:28	-a--
SkinEditor.exe	158.408	25.11.2016 13:29	-a--
Uninstall.exe	186.896	25.11.2016 13:36	-a--
Inside "Modules" folder ;
boot\	<DIR>	14.10.2016 22:48	----
htdocs\	<DIR>	14.10.2016 22:48	----
Anysee.eBDA	87.240	25.11.2016 13:30	-a--
Astrometa.eBDA	118.984	25.11.2016 13:30	-a--
AverMedia.eBDA	387.784	25.11.2016 13:30	-a--
Azurewave.eBDA	328.904	25.11.2016 13:30	-a--
BDA.Device	367.304	25.11.2016 13:29	-a--
DigitalDevices.eBDA	87.240	25.11.2016 13:30	-a--
DVBSky.eBDA	115.912	25.11.2016 13:30	-a--
DvbWorld.eBDA	314.056	25.11.2016 13:30	-a--
flv.trf	415.432	25.11.2016 13:30	-a--
Geniatech.eBDA	321.736	25.11.2016 13:30	-a--
GotView.eBDA	90.312	25.11.2016 13:30	-a--
Hauppauge.eBDA	93.896	25.11.2016 13:30	-a--
irremote.DLL	128.264	25.11.2016 13:30	-a--
kworld.eBDA	317.640	25.11.2016 13:30	-a--
mp4.trf	230.088	25.11.2016 13:30	-a--
NetClient.Device	482.504	25.11.2016 13:29	-a--
Nova_PCI.device	50.376	25.11.2016 13:29	-a--
Nova_USB.Device	46.280	25.11.2016 13:29	-a--
Nova_USB2.Device	46.280	25.11.2016 13:29	-a--
ogg.trf	117.448	25.11.2016 13:30	-a--
Omicom.eBDA	127.176	25.11.2016 13:30	-a--
Omicom.ini	431	31.10.2011 03:10	-a--
PidRecorder.module	324.808	25.11.2016 13:29	-a--
ProgMediaServer.Module	2.605.768	25.11.2016 13:29	-a--
Sky2PCAVSrc.ax	143.872	30.03.2010 15:35	-a--
skydll.dll	99.528	25.11.2016 13:31	-a--
SkyStar2.Device	386.760	25.11.2016 13:29	-a--
TBS.eBDA	485.576	25.11.2016 13:30	-a--
TBS.eBDA2	315.392	27.03.2014 02:01	-a--
TBS.ini	339	16.04.2013 02:02	-a--
TbsCIapi.dll	367.816	25.11.2016 13:31	-a--
TbsCIapi1.dll	367.816	25.11.2016 13:31	-a--
Technotrend.eBDA	112.840	25.11.2016 13:30	-a--
Technotrend.eBDA2	285.184	27.03.2014 02:00	-a--
Technotrend.ini	432	16.09.2012 20:51	-a--
Tevii.eBDA	90.824	25.11.2016 13:30	-a--
TSReader.Device	121.544	25.11.2016 13:29	-a--
ttBdaDrvApi_Dll.dll	206.024	25.11.2016 13:31	-a--
ttlcdacc.dll	566.472	25.11.2016 13:31	-a--
ttusb2acc.dll	451.784	25.11.2016 13:31	-a--
ttusbacc.dll	427.208	25.11.2016 13:31	-a--
wmv.trf	134.856	25.11.2016 13:30	-a--
I don't find "ProgDVBModules.ini" file !? :?
