Hi,
I tried to use de Record function over EPG. After this, there is a command line in the Scheduler using the command Record.
If it starts recording the Button to record in Main Window gets marked, but nothing gets recorded.
If I press the button to record in the Main Window it stays marked, but then ProgDVB records.
Now I do it manual with the command start/stop recording at specified times. This works fine.
Thanks
Bimon
Download V5.12.3 Install V5.12.03
#137Hi,
if I download Version 5.12.3 of ProgDVB Version 5.12.03 gets installed!?
#138
This is not a different version, but just a tiny names convention inconsistency issue.
Maybe Prog will correct this one day, but until then, just ignore the leading zero.
Be assured, this will not matter in any way, except of using the search function for a version number, perhaps.
Some little bugs
#139Dear Prog,
as I told with Jurgen with Progdvb professional 4.88.x now I have upgraded to 4.88.2 all works good and I have noticed these bugs:
-sometimes (on the order of some minutes) I have a little tic (loss of signal) for just a momement (so I listen the tic) and only if I use the CAM
-another minor bug I noticed was that if I install progdvb with timeshift option -> in memory then when I see the channel progdvb freezes and becomes unresponsive (need to close in taskbar).
Hoping being helpfull.
Bye
Bye
Opteron 175 @ 2,2 Ghz (on gigabyte nforce3 Ultra), Radeon HD 3850 512 MB, Digitalrise 1041+CI, Th 1.1.0.4 driver, 1 GB RAM, Windows XP Pro
#140
I think so. I'll try if the other thing is fixed now, well I miss it...the thing with EPG and Record. I did it always with Start/Stop Recording and that's going on my nervesthis will not matter in any way
It's running!!!! Thanks to Prog and people who helped!!!!!!!!!!!!
#142
Hi again,
the thing with recording over EPG runs but not very well. The recording always crashes and since yesterday it doesn't even start recording itself, ProgDVB just shows that it is recording but it don't as before.
It's such a nice function EPG->select->record->OK->finish, but please make it working
#143
This did work on all earlier versions, so perhaps go for or stay with an older version, until this gets fixed.
#144
Version : 5.12.4 Pro
Problem/Bug : The /startrecord switch does not work
progdvb /stoprecord /ch:1 /ch:2 /exit = works
progdvb /startrcord = doesnt work
progdvb /stoprecord /ch:1 /startrecord = doenst work
please fix this
without the startrecord switch its nearly impossible do to scheduled recordings.
Edit : Version 4.88.4 Pro also
please fix this
#145
This seems to be the very same bug.
#146
Hello,
Using ProgDVB 5.12.4 and noticed some issues:
- * Nothing happenes on File >> Exit. I can only exit by clicking on the red X button.
* I'm unable to use the remote control of my TechnoTrend TT-Budget S2-3200. Is this a bug or am I doing wrong something?
* When I set the TimeShift buffer location to disk (C:\timeshift.dat) instead of memory and set it to 1024 MiB then restart the application, it freezes and won't start up until I delete the settings file or edit it to store the TimeShift buffer in memory again.
#147
Last issue may be user rights or disk quota related.
Try another place
Others, no idea.
Perhaps someone else can help or confirm?
p.s.
I've seperated the remote discussion into it's own thread. Too much for this bug report thread....
Try another place
Others, no idea.
p.s.
#148
The bug decribed by birmon on Dec 02 (recording does not start) continues in 5.12.8
Frank
Frank
GA965P; Core2Duo 2,1 Ghz; ATI 1600XT PCIe; 2Gb; TT Premium 1.3 moded, driver: TT 2.19h software mode; WinXP;
#150
Hi Prog,
thanks for your response.
If I want to make a scheduled record, all what happens is: the Record symbol becomes activated at the start time.
- no channel change
- no 'red spot' in the window
- no record file creation
One click at the already marked record button starts the record. (But not the channel change of course)
There is no difference between FTA and pay TV.
Greatings
Frank
- no channel change
Greatings
Frank
