Re: FFmpeg player No sound
#16
It’s vaders iptv services, When I install it to the first they work, but when there are several I said 'error', I installed ffmpeg code with a command terminal, Openmax code no work, mediaplayer + no work, ffmpeg I have worked but very slow and pixelated. the only one that works is mediaplayer, It’s in all channel.
#19
lenifloww wrote: ↑
Tue Jan 30, 2018 10:54 am
If you get video but no sound using OpenMax right click your remote for the menu to open on left side of screen. You will see "Streams" on top click on it and change the stream until you find the 1 that will include the sound for that channel.
