Re: 7.326 #16 by Prog You can try x32 version of ProgDVB. For using of x32 of codecs and drivers. But update of video driver is best idea. QuoteMon Feb 24, 2020 9:01 pm
Re: 7.326 #17 by Ernst1952 Why shhould i downgrade from x64 to x86 ? My nvidea-drivers are up to date. Onnly difference is on x64 i had to use elecard codec-pack on x86 not. btw, which video driver do you mean ? QuoteMon Feb 24, 2020 9:07 pm
Re: 7.326 #18 by Ernst1952 Do you have a version greater 7.32.3 and less 7.32.6 (x64) ? if you have, i will test it. QuoteTue Feb 25, 2020 9:27 pm
Re: 7.326 #19 by Prog You can try same codecs in both versions of ProgDVB. May be problem only with elecard? QuoteWed Feb 26, 2020 6:02 am
Re: 7.326 #22 by Prog In codec properties. But please check without elecard. I am need some idea for find reason of problem. QuoteWed Feb 26, 2020 12:24 pm
Re: 7.326 #23 by Ernst1952 Sorry prog, i was on thhe wrong way. i do not use elecard codecs but ffdshow codecs. Thex are dated form oct. 2018 now i installed a new version foom end of 2019. i ´ll see what happend installing 7.3.26 later. QuoteWed Feb 26, 2020 1:10 pm
Re: 7.326 #24 by Ernst1952 After setting Codec from EVR Custom to EVR the new version works perfectly. QuoteThu Feb 27, 2020 4:23 pm
Re: 7.326 #26 by Ernst1952 no nothing. Installing new version. tested "flickering" settin EVR Custom to EVR all okay. No restart or something. QuoteThu Feb 27, 2020 4:53 pm
