Re: Display issue 4k
#17
I recently updated to 7.33.06 from 7.27.3 and am having the same issue. It looks like this might be because when using a TV (mine is a Samsung UN46D8000) with Windows 10, the recommended scale for text is 150%: https://imgur.com/3pd5Q7G
150% Text Scale
https://imgur.com/VugEUUv
https://imgur.com/w6Ucvap
100% Text Scale
https://imgur.com/pJTagKq
Unfortunately, when using 100% text scale, text is very small on the screen and hard to read.
EDIT: Found a fix
From desk icon go to Properties Go to Compatibility > Change High DPI Settings > Check off Override high DPI scaling behaviour and choose System (Enhanced) from the drop down menu
https://imgur.com/C6fecTr
#19
phunksouljah wrote: ↑
Mon Apr 20, 2020 8:27 am
150% Text Scale
100% Text Scale
EDIT: Found a fix
hello :phunksouljah
Very excellent solution
Working successfully now choose System (Enhanced)
Thank you very much
مركز الخليج
#21
Not compatible with Windows 10.
Version 7.48.5
I can't watch channels
due to incompatibility with Windows
Version ProgDVB_(64bit)_v7.32.2. There is no problem and it works successfully
EDIT: Found a fix Version 7.48.5
