Prog wrote:ProgDVB only show value from driver. But driver can return different values.
But again. What is 100% what is 50% ?
Hi my master,
Thank you for your interest.
I'm living KYRGYZSTAN.
So according to this location, with 53% "signal level" is quite a good level.
When I look with BCM4505 tuner dreambox 800se, is around 68%. So, every time the signal DreamBox, 14% by weight, and larger shows.
Between 37% to 39% not breaking, I'm getting HD broadcasts.
DVB-S2/8PSK transponder ; Signal level %34 and not breaking
"The lower signal ratio" with not breaking, there are publications that I can get.
As for your question;
Due to the use of BDA drivers, "signal bars" one of, is not realistic.
For me, "signal level" important "quality level" So that's it for me, is an acceptable level.
Of course, such as the WDM drivers, "Both signal indicator" "realistic values" and I'd like to view too. I accept it with so the BDA.
Regards.
