Re: Pausing Live TV
#33
ravo1957 wrote: ↑
Sun May 26, 2024 2:32 pm
is there an earlier version i can go back to?
It would be better to send logs to Prog. If you are afraid to post it here, then use e-mail
prog@progdvb.com
It is very simple and safe.
1. You need to open Settings of ProgDVB, then
2. Open Options, then
3. Open Debug and Repair, then
4.0. Switch Logs on, then
4.1. ProgDVB will close and open again.
4.2.. Afterwards you just need for this odd situation to happen, then
5. Click on Export Logs, then
6. Save Logs where you want on your disc, then
7. Attach Logs here or to e-mail letter to prog@progdvb.com
And Prog will find out from the Logs where is the problem and will solve the problem.
Re: Pausing Live TV
#41
ravo1957 wrote: ↑
Wed May 29, 2024 2:59 pm
yes in my last post. i will try a few times then send the log.
I once found myself in a similar situation. I pressed a button that I thought was responsible for one function, and it was responsible for another. Maybe you're pressing the wrong button?
You need to press where the arrow points in the screenshot - on two stripes surrounded by a square.
