Hello everyone, I have a big problem.
I have TBS8922 a satellite card, and an antenna with motor sat tracker3. I installed x86 progdvb but can not find the way to move the antenna. There is a plugin interface or form to be able to turn the antenna? (Type ss2diseqc for SS2 card)
Thank you
Re: TBS8922 dvb s/s2
#3Already it has done but does not run the same.
I selected my card from the setup but the same does not turn my antenna.
I had to install my old SS2 technisat to turn the antenna.
I saw on the net there are many users with this problem on board TBS8922
Anyway, thanks the same for the attention
