Hello, I use the free ProgDVB since quite some time and was very satisfied.
But since several weeks the program crashed every time I open it and tries to restart automatically. A window pops up which says:
Restarting after crash
The application has terminated under abnormal condition.
If an error ....
(stroke trough is following text:)
Closing of old application instance.
Moving of logs to C:\ProgramData\ProgDVD\Logs\Report
I am using Windows 10and ProgDVD64
Any helppossible?
Regards
Re: Chrash at start of ProgDVB
#3Prog wrote:viewtopic.php?f=2&t=24&start=1740
Still it does not work.
I used the linked workaround and installed the LAV Filter program.
In the workaround it say "start ProgDVB", but it crashes still, so no settings can be done.
#4Now it works:Prog wrote:viewtopic.php?f=2&t=24&start=1740
I also had to de-install the KB4013429, than install LAVFilters and finally made changes in the ProgDVB Settings as described.
Thanks!
