crash just to press a channel (maybe i have solved)
    • ProgServer
    • ProgMusic
    • ProgFinder
    • Elecard ViCont
  • Privacy Policy
1 post
un_ottico1965
un_ottico1965
Sat Aug 24, 2013 5:23 am
#1 by un_ottico1965
hi, the fast crash i think was because progdvb don't support 8 tuners.
till today i have work with 5 of 8 tuners and all was ok.
when i have try to turn on the 3 remaining tuners, the program
had crash just to touch 1 channel.
right now i have open 3 tuners, search channels
and all is fine.
now i go for sure to turn on till 5 tuners, and must be ok,
but if i try to open the 6th tuner, all crash.
i wrote when i'm at 5 tuners opened.
bye.
  • Sun Aug 20, 2017 6:06 pm
1 post
User avatar
  • It is currently Fri Oct 30, 2026 3:09 pm
