crash just to press a channel (maybe i have solved) part3
1 post
un_ottico1965
un_ottico1965
Sat Aug 24, 2013 5:23 am
#1 by un_ottico1965
ok, found the bug.
when i finish to search the channel list of the sixt tuner,
after that i press 1 channel, progdvb crash without window error.
can you fix the problem for the octa-tuner card ???
in my case is the tbs 6209.
thank very much.
  • Sun Aug 20, 2017 6:43 pm
1 post
Re: Вывод звука wasapi и asio
  • It is currently Sat Sep 19, 2026 11:44 pm
